Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Sound System Install
Old 06-06-2011, 01:54 PM   #14
Tony407
Tony407's Avatar
Fan#: 85289
What I Drive: 2012 Sterling Gray Hatch Titanium
Points 11,374, Level 70
Points: 11,374, Level: 70 Points: 11,374, Level: 70 Points: 11,374, Level: 70
Level Up 31% Completed
FF Reputation: 4 Tony407 Good Standing Member
Originally Posted by automated View Post
Tony- I'm about to buy with the MFT/Sony package, would you recommend staying away or is it worth it to have everything set up and fairly easy to just swap out? Thanks.
Well, I can only recommend it only if you're like me, which you're probably not (thank god for you!!! LOL). I'm not done with the install, but assuming everything goes as planned it should be a fairly easy integration. But who knows, there's usually something that throws a wrench into the works. But I'm fairly confident that with the LCQ-1, amp(s) and a new sub everything should come together nicely.
I wanted the MFT because I'm a tech geek, and since the Sony came with it that's what I got. MFT certainly has more than its fair share of glitches, but hopefully Ford will correct the problems soon. Other than that I'm pretty happy so far.
Hope that helps.
Tony
Tony407 is offline
