Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Can you open all doors with ONE PRESS on key fob on the 2012?
Old 06-04-2011, 07:59 AM   #7
Josh321
Fan#: 85263
What I Drive: 2012 Focus Titanium 5-door
FF Reputation: 1 Josh321 Good Standing Member
The default setting is two-stage unlocking where the first button press unlocks the driver's door, and a second press unlocks the remaining doors (including the trunk/liftgate). According to the owner's manual, you can reprogram it where a single button press unlocks all doors. You hold down the lock and unlock buttons together, and then the hazard lights will flash to confirm the change. The same procedure also happens to work on TransitConnect vans, I found out.
Josh321 is offline
