Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SaleenT's Duratec 2.0L Build
Old 05-26-2011, 07:09 PM   #5
SaleenT121
SaleenT121's Avatar
Fan#: 57997
What I Drive: 05 Saleen Focus
Points 3,302, Level 35
Points: 3,302, Level: 35 Points: 3,302, Level: 35 Points: 3,302, Level: 35
Level Up 68% Completed
FF Reputation: 3 SaleenT121 Good Standing Member
Buy-Sell-Trade Rating: (3)
While the car is apart i had decided to upgrade the clutch from my previous spec stage 1 to a spec 2+ 6 puck. I only had 1000 miles on that thing but spec re searfaced my flywheel and upgraded it for cheap. The factory 2.0 had a dual mass so i decided to use an Exedy OEM replacement single mass that is a good bit lighter that that hunk of dual mass garbage. It added up to be about 9lbs lighter than factory....
Note : The spec clutches you buy will not fit the Exedy 2.3L flywheel.
They will fit the factory(flywheel) only, the clutch seems to be too big!
Spec is trying to fix this issue, since you cant machine our flywheels.
They will match your clutch with whatever flywheel choose to you have.
Saleen Focus #74
-Carbon Hood and trunk
-SVT rear Disc brake conversion
-Custom fab turbo kit
-Built 2.0L by Turbo Turtle
SaleenT121 is offline
