Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Focus HID
Thread: 2012 Focus HID
Old 05-23-2011, 03:10 PM   #16
Tony407
Tony407's Avatar
Fan#: 85289
What I Drive: 2012 Sterling Gray Hatch Titanium
Points 11,374, Level 70
Points: 11,374, Level: 70 Points: 11,374, Level: 70 Points: 11,374, Level: 70
Level Up 31% Completed
FF Reputation: 4 Tony407 Good Standing Member
Originally Posted by clutchrider View Post
My only additional comment would be that owning an F-150 and being a lot higher off the ground means your US DOT stock lamps are definitely not meant to perform with HIDs.
US lamp regulations do not require cars to have their lamps aimed at any particular degree up or down depending on the height of the vehicle. Therefore my Matrix and your F-150 utilize the same plane for aiming the lamps whereas in European standards, a taller vehicle would be required to have proper aiming so the beam points slightly downward relative to the lamps distance from the ground.
It's the same reason a lot of the luxury cars with projector HIDs in the US have auto-level as an option or standard equip. It's standard to have in Europe. So adding an HID to something that is already taller than a standard car means a lot more scattered light gets tossed around to other people.
I could go on for paragraphs about lighting as I've spent a lot of time/money/effort in applications and research on the topic and my own trial/errors with cars.
My F150 has a 4" lift with 35 inch tires. No glare. No pissed off drivers. I've looked at them in a buddy's car when he's driving my truck and they aren't any worse than any other car on the road.
Tony
Tony407 is offline
