Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help! I attempted (and failed) to calibrate needles
Old 05-19-2011, 06:07 PM   #4
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 22,800, Level 93
Points: 22,800, Level: 93 Points: 22,800, Level: 93 Points: 22,800, Level: 93
Level Up 45% Completed
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
Originally Posted by gordoncave View Post
Yes! Sort of. I finally got the car into Test mode but anytime I adjust the needles while I am driving they go crazy when I shut it off.
trick for RPM hold the gas till the car is at 3000 set the needle. Next for the speedo, take the bottom pin out and put the needle on below it at the 7 oclock angle then push the needle up and put the pin back in and drive the car you should be damn close if not keep repeating that process till your dead on.. Gas is easy fill her up and put her past the full line slightly. Next is the temp gauge let the car idle and then put the needle at the middle when its at running temp, your all set!
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is offline
