Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - *Massive Polyurethane Lower Motor Mount Inserts 00-07 Back in Stock!*
Old 05-17-2011, 04:08 PM   #1
K Dog
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 17,811, Level 84
Points: 17,811, Level: 84 Points: 17,811, Level: 84 Points: 17,811, Level: 84
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Buy-Sell-Trade Rating: (19)
We appreciate everyone's patience in dealing with the shortages we had the last 4-5 weeks. We did receive our latest shipment last week though, and everyone who had a backorder should have received them by now. Thanks for holding out!!!
After much trial and error, we are pleased to report the latest pouring has achieved a much more pleasant purple color than the last, more "cabernet" appearance (seen in bottom image). :)
We think you'll agree they're the most beautiful lower motor mount insert in existence. :D
They still possess a full 95A hardness, making them the toughest on the market.
Full description:
Excessive wheel hop plagues the Focus in standard form. Not only is this an embarrassing stop light antic, but of course it will seriously impede your ability to smoke that Camaro or Cobalt in the next lane. This also puts incredible shock and abuse on all drive line components and is the leading cause of axle failure. Upgrade to custom Massive spec polyurethane bushings for the best in motion control. Adds some real stiffness to the motor, drastically reducing movement. Expect better shift feel, no more loud banging noise from the stock mount bottoming out on hard shifts, less wheel hop, and more power to the ground! These mounts also are designed in such a way that the inserts can not come dislodged from the housing.
EXCLUSIVE: Massive ALSO includes our complete HIGH STRENGTH HARDWARE kit! Even stock foci have been know to break OE hardware, and with the added stiffness of your new mounts, failure of low grade stuff is inevitable. Often times corrosion will make re-using factory hardware impossible. We selected the highest quality high vis Mil spec blue coated grade 12.9 European hex head cap screws for the ultimate in strength.
Very straight forward installation. If you need assistance, let us know and we’ll walk you through it! Should take less than 1 hour for the average car guy (or girl). Kit comes with instructions. Signature Massive PURPLE bushings. Super high quality construction. Quality made right here in the USA!!!
Regularly $29.95, but use coupon code MSSISBEST through the end of the month for 10% OFF ALL MASSIVE - Net cost just $26.96!!!
Find em Here
massivespeedsystem
K Dog is offline
