Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO Replacing Rear Upper Camber Arms, and camber bolts.
Old 05-14-2011, 09:59 PM   #24
JBotone
JBotone's Avatar
Fan#: 78479
What I Drive: 2003 Pitch Black SVT 5 door
Points 1,176, Level 18
Points: 1,176, Level: 18 Points: 1,176, Level: 18 Points: 1,176, Level: 18
Level Up 76% Completed
FF Reputation: 1 JBotone Good Standing Member
Originally Posted by Djzx3 View Post
So then if it is welded, do you grind it off?
Or will the new bolt be a exact fit to the old nut?
I have the camber arms being put on by a shop now, I could not take the risk of the upper bolts breaking like the lowers. I'll let you know if they are welded when I get it back. If you're taking lose the upper bolts to put on new camber arms, you'll use the old bolts to bolt it back up.
2003 Pitch Black SVTF, K&N Drop in, CFM dog bone. 155,000 miles. **SOLD**
2001 Sentra SE 2.0 w/JWT Pop Charger. RETIRED with 511,000miles.
2008 Setra SE-R Spec-V 187whp. 167 lb. ft.
JBotone is offline
