Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Would you buy a FORD FOCUS DIESEL?
Old 05-09-2011, 04:14 PM   #1
DJ2BIG's Avatar
Fan#: 49192
What I Drive: 2012 Winter Frost SE
Points 3,392, Level 36
Points: 3,392, Level: 36 Points: 3,392, Level: 36 Points: 3,392, Level: 36
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
FF Reputation: -6 DJ2BIG Poor Behavior Needs Improvement
Ford has introduced a diesel-powered Focus in Europe, called ECOnetic, that gets a claimed 80 mpg. It uses technology such as engine stop/start, low-rolling-resistance tires, brake regeneration and active grille shutters to get that number.
Under the hood is a turbocharged 1.6-liter diesel, mated to a six-speed manual transmission. The engine is rated at 105 hp.
Of course, there are a few asterisks.
First, that fuel-economy number is calculated using imperial gallons, which are 20 percent larger than U.S. gallons.
And the fuel economy is calculated using the British test standard, which has virtually no relation to the method the EPA uses to calculate mileage for U.S. cars.
If we did run the Focus ECOnetic through the U.S. test, the result would likely be fuel economy in the high 40s or low 50s--about two-thirds the U.K. rating.
muzik lives!
DJ2BIG is offline
