Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Will i throw a CEL code if i take my passanger seat out?
Old 04-27-2011, 10:06 PM   #2
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
Points 15,151, Level 79
Points: 15,151, Level: 79 Points: 15,151, Level: 79 Points: 15,151, Level: 79
Level Up 61% Completed
Well it threw an airbag light i guess because it wasnt hooked up. Looks like its just an air type of pressure switch or somthing.
I bought a torx set from sears, its a 3 bit set for a 3/8 drive came with 40-45 and 50.
Its good because you can really crank on the ratchet. Some of them are in pretty good and i had to use a 1/2" drive extension.
Once you bust em loose you can use a flat head to spin em out the rest of the way. You could use a flat head to get em out to if you were good.
While i had em out i tried to clean the carpet good. Its kinda hard to get down inbetween the seats with them in.
BowerR64 is offline
