Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to remove 2008 Ford Focus Radio
Old 04-26-2011, 04:17 PM   #34
Gazookz
Gazookz's Avatar
Fan#: 82103
What I Drive: 2011 Metallic Gray Focus SE
Points 658, Level 13
Points: 658, Level: 13 Points: 658, Level: 13 Points: 658, Level: 13
Level Up 16% Completed
FF Reputation: 5 Gazookz Good Standing Member
Originally Posted by UFC205 View Post
Hey guys so is it possible to use the stock head unit and just connect an amp and subs to it? Or will i need to replace the headunit if I want to use my sub and amp? Thanks in advance guys!
yeah it's possible...I have that done on my '11 Focus SE. I just used a LOC(Line-Out Converter) to get the RCA's and then put a switch on a 12V+ source to get the remote for the amp...pretty simple once you removed the dash and it works great! I suggest getting something to boost the voltage output level for the RCA's...i used an equalizer that gives 7 volt rca output. good luck
Gazookz is offline
