Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - STFT = Lambda ... ?
Old 04-11-2011, 08:07 PM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 66,383, Level 100
Points: 66,383, Level: 100 Points: 66,383, Level: 100 Points: 66,383, Level: 100
Forum Activity 99%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Originally Posted by iminhell View Post
Sweeet!
Bear with me here.
So if my WBO2 reads 'rich' (which is richer than 0.68 Lambda) at very high RPM's, over 6k and over 800 counts, but my STFT reads 0.85, which is what I'm commanding ... Then I should assume it's my timing that needs to be adjusted, correct?
Because firing the plug earlier would allow more burn time and bring the WBO2 back to where it should be.
Or am I thinking about this wrong?
Not exactly if your WB reads rich then you need to change your MTF IF you have the base fuel tables set to what you want the targed to be
Set your base fuel tables to what lambda target you want then change the MTF to get the AF to match what AF/lambda you want
Timing will do little to change the AF
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is online now
