Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Zetec Timing problem
Old 04-02-2011, 11:04 AM   #17
Badad
Fan#: 84540
What I Drive: Silver 2011 Ford Edge
FF Reputation: 1 Badad Good Standing Member
Usually if compression is good Timing is good. Unless you have a tester that will read codes and hopefully pids it will be hard to check sensors. It sounded like a converter at first but since you said you have removed it that cant be the problem. I would go after the MAF sensor or the IAT because both of those will cause rich conditions.
Badad is offline
