Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Knock Sensor spark?
Old 03-15-2011, 07:30 PM   #1
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,205, Level 93
Points: 23,205, Level: 93 Points: 23,205, Level: 93 Points: 23,205, Level: 93
Level Up 86% Completed
Level up: 86% Level up: 86% Level up: 86%
Forum Activity 12%
Activity: 12% Activity: 12% Activity: 12%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Knock Sensor spark?
KNK_SEN_RETARD is what it's called, or what I'm talking about.
When the number is positive it it adding spark, advancing, or retarding spark?
I assume it's adding spark but I just want to be sure.
Also, should I let the knock sensor do it's thing or should, can, I adjust the timing at those loads to keep the sensor from adding or removing timing ... much the same process as doing the MTF?
Something like you'd only want to see the KS add/subtract 0.5* at most instead of the -5 to +6 I'm seeing now.
Steady throttle, 60mph, on my way home I logged and all the KS did was add timing, positive numbers, moderate loads, 0.65 and below ... but load for me right now is all screwed up I think, WOT nears 1.9 for a load vs the 1 I think it should be; figure that out when I can, if I can.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
