Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW TO: IMRC Removal and Repair
Old 03-14-2011, 03:19 PM   #52
bostonman
Fan#: 83471
What I Drive: 2003 silver focus SVT
Points 25, Level 1
Points: 25, Level: 1 Points: 25, Level: 1 Points: 25, Level: 1
Level Up 49% Completed
FF Reputation: 1 bostonman Good Standing Member
Do the IMRC repair w/o removing the SPI clip
Originally Posted by Davey Boy View Post
I think that would work fine if you don't mind soldering when its down there. The gears aren't screwed in place, but you can probably get the board off without spilling gears. They aren't terribly complex to put back together if you do drop them though, my dad took them out and cleaned them up while I was cleaning my connectors and had no trouble putting it back together.
Thanks.
To make the access eaier, I think I can remove the wheel, then the black rubber splash guard behind the wheel (should be easy), then the area will be wide open.
Tat
bostonman is offline
