Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Mexican Focus RS Mk2 Tuning Plan
Old 03-04-2011, 11:14 AM   #76
pkrehbiel
pkrehbiel's Avatar
Fan#: 75117
What I Drive: 2010 Verde Electrico Focus RS Mk2
FF Reputation: 4 pkrehbiel Good Standing Member
Updated Mexican RS Tuning Plan
Mexican Ford Focus Baseline Dyno Run:
Baseline Wheel Power on Chassis Dyno:
298 ft-lbs at 3400 rpm
260 hp at 6000 rpm
Add back the 14% loss through the Powertrain and you have
340 ft-lbs at 3400 rpm
296 hp at 6000 rpm
Which is right on the factory spec's for power at the crank
324.5 ft-lbs at 2250 rpm
300 hp at 6000 rpm
Tuning Upgrades:
- Pumaspeed - Focus RS Mk2 Upgrade 440 Bhp
Pumaspeed EURO Phase 5 remap/reflash - Speed limiter removed
Full Turbo Back De-Cat Exhaust System by MILLTEK SPORT
o Milltek Sport Cat Back MotorSport Exhaust System
o Milltek Sport Decat pipe
o Milltek Sport 3 inch Down Pipe
ITG Air Filters Maxogen CAIS
High Power Intercooler by PRO ALLOY - BLACK version
Bosch 650cc High Power Multi-port Injector Set
Upgraded Phase/Stage 1 Hybrid Turbo
o Ported to a higher degree including the collector throat.
o Balanced to the ultimate tolerance
o Billet aluminum Forge actuator for higher wastegate lift
o New specification 'Cut Back' turbine wheel for higher flow
- Pumaspeed - AP Big Brake Front Kit:
Genuine AP 6 Pot Calipers
Genuine 362mm diameter discs
2 AP Racing 6 Pot dust sealed calipers
2 AP Racing 362 x 32 12 grooved discs
1 litre AP Racing dot 5.1 brake fluid
2 braided front brake flexy lines
2 Aluminum brake mounting brackets (anodized)
2 Aluminum bells (anodized)
1 set Ferrodo DS2500 brake pads
Full fastener kit
- Pumaspeed - KW Variant 3 Coil Over Suspension kit
100% Stainless Steel.
Pumaspeed have been testing the new top of the line stainless steel variant 3 fully adjustable suspension system from KW. With testing sessions on the road ,track and infamous N-ring focusing on all aspects of handling we are happy to offer the most rounded suspension system for the new Focus RS Mk2
Lowering is adjustable anywhere from 10mm to 50mm
KW are the Exclusive supplier to the Ford Motor Company's performance division for Ford Focus Suspension systems and components for FORD RACING !!
- Pumaspeed - High Power 6 Paddle Clutch
Clutch to eliminate slipping over 400 bhp
6 paddles make for much smoother operation
Genuine Ford cover plate from the Focus RS Mk2 2009
Pumaspeed Sourced friction plate
A new introduction from Pumaspeed. With power output reaching over 400 and soon the hit the 425 and with turbo kits 450 Pumaspeed have launched the New 6 paddle version clutch for the New Focus RS Mk2 2009. Built to handle power above 400bhp this unit has been designed to work with the existing hydraulic slave and Ford Dual Mass Flywheel to ensure an even smoother operation than the 5 paddle and solid flywheel versions.
- Team Torquesteer - Focus RS Sitech Intake Manifold (Green)
- Team Torquesteer - Focus RS Lower Rear Engine Torque Link (Black)
- Team Torquesteer - Focus RS Silicone Hose Kit (Green)
- Demon Tweeks - KW 20mm Wheel Spacers
- Auto Specialists - Ultimate Stainless RS Mk2 top induction pipe
Engine Dress & Exterior Upgrades:
- Team Torquesteer - Engine Compartment Dress Pro-Series Black
Focus RS Pro-Series Black Alloy Oil Filler Cap
Focus RS Pro-Series Black Alloy Dipstick Handle
Focus RS Pro-Series Black Alloy Washer Bottle Top
Focus RS Pro-Series Black Alloy Power Steering Cap Cover
Focus RS Pro-Series Black Alloy Header Tank & Cap
- Team Torquesteer - Focus RS Daytime LED Running Lights
- Team Torquesteer - Focus RS500 Black Wheel Nuts
- Team Torquesteer - RS Door Pillar Badge
- Streamline Carbon - Ford Focus RS Mk2 Carbon Fibre Exterior Dress
Exterior Trim Package:
o Pair of painted/carbon bonnet vents
o Grill/Hood Front trim strip
o Pair Mirror covers
Engine Cover Set:
o Fusebox Cover
o Battery Cover
o Replacement front slam panel
Pair Door Pillar Trims
Pair Under Headlamp Trims
2010 Ford Focus RS Verde Electrico ...1996 Porsche 993tt Silver/Black
2006 Exige S Graphite Gray & Yellow ..1967 Pontiac Firebird 400 "Blown Bird"
2002 MINI Cooper S JCW #720 EB/W .1964 Lincoln Continental Black/Red
pkrehbiel is offline
