Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - PRP / Advantage III ?'s
Old 02-28-2011, 04:23 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,197, Level 93
Points: 23,197, Level: 93 Points: 23,197, Level: 93 Points: 23,197, Level: 93
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 11%
Activity: 11% Activity: 11% Activity: 11%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Found my idle issue but I'm not sure where to fix it at.
What happens is when the car switches from the cold idle fuel table to the based fuel table the idle goes to shit and the car stalls out, timing also goes wonky. Just before the switch the STFT's are pegged at 0.750, MAF AD is pretty stable at 67, air flow #/min is the same at 0.355469 (remember I'm using the MAF cal from a 1995 Mustang GT, Link).
Now do I alter the cold and base fuel tables? Basically make them match per CHT (which I selected the transfer function for single resistor CHT, I'm using a SVT ECT sensor spliced into the zetec CHT, was necessary with the head swap, doesn't work perfect and I know it's some of the problem)
When the STFT's are at 0.750 the idle is very stable.
The way it looks (I wasn't logging CHT at the time and I know I should of) once the car is warmed up the STFT's stabilize and hold at 0.750.
So if I assume my MTF is wrong do I multiply the counts or the air flow by 0.75?
Below is my MTF and I edited it into the cleanest readable format I can the site allows, [ left ] and [ center ] formatting tools.
1023.984375
41
1023
34.25
969.390625
29.7001953125
918.375
25.634765625
867.34375
21.9912109375
816.328125
18.7431640625
775.515625
16.4150390625
734.6875
14.3076171875
693.875
12.38671875
653.0625
10.6865234375
612.25
9.150390625
571.421875
7.7763671875
530.609375
6.5546875
489.796875
5.4833984375
448.984375
4.5400390625
428.578125
4.12109375
408.15625
3.7255859375
387.75
3.3525390625
360
3.015625
346.9375
2.7177734375
326.53125
2.3984375
306.125
2.130859375
285.71875
1.8916015625
265.3125
1.6533203125
244.890625
1.443359375
204.078125
1.0830078125
153.0625
0.7333984375
102.046875
0.55859375
81.625
0.384765625
0
0
Yesterday I'd logged something different just seeing if it works. The max #/min I'd hit was a touch over 20 and air temp was about 0*F, which is about dead on (table below based on the zetec engine spec's)
RPM
Lb./Min 0F
1000
3.368724499
1250
4.201764795
1500
5.031196278
1750
5.857042348
2000
6.679326203
2250
7.498070842
2500
8.313299066
2750
9.125033479
3000
9.933296494
3250
10.73811033
3500
11.53949702
3750
12.33747841
4000
13.13207616
4250
13.92331174
4500
14.71120644
4750
15.49578139
5000
16.27705752
5250
17.05505559
5500
17.82979619
5750
19.36958647
6250
20.13467647
6500
20.89658965
6750
21.65534575
7000
22.41096436
7250
23.16346489
7500
23.91286661
7750
24.65918862
8000
25.40244986
8250
26.14266912
8500
26.87986505
8750
27.61405612
9000
28.34526067
9250
29.07349689
9500
29.79878281
9750
30.52113633
10000
31.24057519
I'll go log more and play but I'd like some answers/opinions to my questions.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is online now
