Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Attention 2008-2010 Focus owners
Old 01-27-2011, 01:30 PM   #55
Duhamel
Duhamel's Avatar
Fan#: 78883
What I Drive: Black '14 Ti
Points 844, Level 15
Points: 844, Level: 15 Points: 844, Level: 15 Points: 844, Level: 15
Level Up 44% Completed
FF Reputation: 1 Duhamel Good Standing Member
I also had a popping noise from my front end (09 SES), going over bumps usually. Took it to the dealer and they actually used the same TSB. They started with the sway bar links, but that didn't work, which I figured anyway because I looked at the front end and couldn't see any issues with anything "visual". Then they proceeded to the next step, replacing the control arms. Oddly enough, this didn't resolve it either. Then the mechanic had an idea and he was right. Here it was a bolt on the rack and pinion, once he tightened the bolt the noise was gone. After and alignment I was good to go. My focus only had about 16,000kms on it when the issue occurred.
Duhamel is offline
