Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How the OEM speakers stack up to upgrade speakers (pictures)
Old 01-21-2011, 11:39 PM   #11
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
The rated wattage is a function of many different areas of the driver. The coil, magnet, spider etc. High wattage drivers are made (more or less) for use without an enclosure (as in they will not destroy themselves). There very forgiving in that area, but they loose in efficiency. BTW: Old trick. If you remove that foam pad and (carefully) work some batting to fill up the enclosure, you will increase the internal audio volume by 1.2%. Do NOT let the batting come in contact with the spider or cone. When you tested the woofer, did you still have the crossover in place? If so, test just the woofer (no crossover). the lack of a lower resonance ('Q'), well, it's a tad hard for me to believe.
P.S. What are you using for a signal generator? Is it pure sign or quasi?
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
