Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus RS Build.....For the Occasional Track Day!
Old 01-17-2011, 07:37 AM   #28
thielt1
thielt1's Avatar
Fan#: 32005
What I Drive: Focus RS Rep
Points 11,611, Level 70
Points: 11,611, Level: 70 Points: 11,611, Level: 70 Points: 11,611, Level: 70
Level Up 91% Completed
FF Reputation: 2 thielt1 Good Standing Member
Buy-Sell-Trade Rating: (8)
Update from the weekend:
-Removed front lower subframe
-Removed radiator
-cut out front bumper
I think I will be able to mount the euro front bumper onto the stock plates but room will be tight
I also noticed the two plates are not mounted symetrical to each other (notice the angle on this one where the other is flush)
I also found some extra wiring work as the previous owner thought is was a good idea to wire strobes and other electronics into the ignition and oil pump harness.
Next:
-pulling engine and everything else from engine bay
-finish removing heat shields
-remove rear windows
Focus RS Conversion In Process.
http://www.focusfanatics.com/forum/showthread.php?p=3517025#post3517025
thielt1 is offline
