Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus RS Build.....For the Occasional Track Day!
Old 01-11-2011, 08:09 AM   #22
thielt1
thielt1's Avatar
Fan#: 32005
What I Drive: Focus RS Rep
Points 11,568, Level 70
Points: 11,568, Level: 70 Points: 11,568, Level: 70 Points: 11,568, Level: 70
Level Up 80% Completed
FF Reputation: 2 thielt1 Good Standing Member
Buy-Sell-Trade Rating: (8)
Originally Posted by djzx3 View Post
How hard is it to get RS parts. I would imagine you got to get them from the UK right?
If you haven't sourced your parts for this build yet it will be almost impossible to complete or you better have a lot of money. Part are mainly sourced from the U.K. with some parts coming from the USA and Germany.
what did you use for the door panels? i want to do that this spring!
I used a thin fiber board which I found at menards, I ordered some suede in from hungary, found some foam for the padding and lots of epoxy! I helped someone else on here who I now believe has a sticky in the how to section.
Are you doing the bodywork or fitting a look alike body kit?
All OEM Exterior (all metal panels)
Any projected time for completion?
-I want the body completed and in for paint by May at the latest
-I want the engine and running gear in and dyno'd by July
-If all goes well its First Trackday will be in October after the couple month break-in
I might be done before these dates but only time will tell.
Focus RS Conversion In Process.
http://www.focusfanatics.com/forum/showthread.php?p=3517025#post3517025
thielt1 is offline
