Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - *NEW PRODUCT - Massive RaceSpec Adjustable Rear Toe Arms*
Old 12-21-2010, 05:37 PM   #1
K Dog
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 18,441, Level 86
Points: 18,441, Level: 86 Points: 18,441, Level: 86 Points: 18,441, Level: 86
Level Up 19% Completed
Level up: 19% Level up: 19% Level up: 19%
Buy-Sell-Trade Rating: (19)
Massive has answered the markets new void with the highest quality offering with maximum adjust-ability. For 00-11 Focus.
Here's what we have to say about them:
Replaces stock fixed arm with adjustable. Allows for custom toe in / out set up:
  • Obtain stock settings – many stock/mildly dropped vehicles cannot be set to OE specifications. Massive arms allow alignment to be perfect resulting in optimal handling and proper tire wear.
  • Performance/racing settings – Tune for more advanced settings for max race performance in road race / autocross environments.
  • Rear steer – Massive arms are designed with a far greater degree of positive AND negative adjustment to attain rear steer – perfect for those only turning ONE way (circle track!!!).
Full T6061 billet aluminum .220" wall tie rod is not only stronger than OE stamped piece, but also lighter in weight!
Years of exhausting research at the race track and on the street have led us to these “cost-no-object” Aurora swaged PTFE lined self lubricating oversize 5/8” 15,000 lb rod ends. These spherical joints not only provide the highest in accuracy for ultimate motion control, but are also exhibit extremely low noise operation for the long haul.
Custom made Massive Billet Big OD offset bushings provide extended range of motion, necked design slides into pillow ball for tight fastener clearance thus noise reduction, large load bearing surface to spread load on thin stock stamped bracketry/arms.
Included is the Massive exclusive Hardcore Hardware kit – Mil-Spec blue grade 10.9 190,000 lb tensile strength hex bolts replace your worn, rusted weak factory stuff.
Tie rod anodized Signature Massive Purple or High Gloss Black powdercoat.
As always – made in house here in the USA!!!
Available NOW, Here
Just $159. Remember, use promo code: MSSISBEST and get 10% off ALL Massive products til the end of the year!!!
massivespeedsystem
K Dog is offline
