Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - starting problems
Old 12-16-2010, 09:15 AM   #7
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 02 ZX 3 TURBO , MURDERED.
Points 5,573, Level 48
Points: 5,573, Level: 48 Points: 5,573, Level: 48 Points: 5,573, Level: 48
Level Up 12% Completed
Level up: 12% Level up: 12% Level up: 12%
Forum Activity 4%
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
The IAC ( idle air circuit or control) valve is under the intake manifold. You can remove it and clean it with carb and choke cleaner. Easiest way is from under neath the car. Jack the front end up and put on Jack stands. If I remember there are two 10 mm bolts holding it to the intake. And you can reuse the gasket again if you are careful. But it would be good insurance to get a spare. Before you disable the car. It wont run with the iac out..
iroc34 is offline
