Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - starting problems
Old 12-16-2010, 07:14 AM   #5
steve113
steve113's Avatar
Fan#: 81184
What I Drive: 1.8 lx 16v Zetec 1999 silver
FF Reputation: 1 steve113 Good Standing Member
Originally Posted by spayne13 View Post
Have you cleaned the idle air control valve as well? This valve is a bypass around the throttle body, and can accumulate gunk and stick in the wrong position, causing idle and/or starting problems. The fact that depressing the gas pedal helps overcome the starting problem indicates this valve may be causing issues. Does the car idle OK, or does it have idle issues?
Hi no i have not cleaned idle air control valve were is this and whats best to clean it with would carb cleaner be any good .car idles ok when warm but when cold and coming to a junction and i dip the clutch the revs go up to 2 rpm and holds for a few seconds before dropping back down to normal but only when cold first 5 minutes of driving
steve113 is offline
