Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - starting problems
Old 12-15-2010, 09:27 PM   #3
Fan#: 81196
What I Drive: Silver 2005 ZX4 ST
FF Reputation: 1 spayne13 Good Standing Member
Have you cleaned the idle air control valve as well? This valve is a bypass around the throttle body, and can accumulate gunk and stick in the wrong position, causing idle and/or starting problems. The fact that depressing the gas pedal helps overcome the starting problem indicates this valve may be causing issues. Does the car idle OK, or does it have idle issues?
spayne13 is offline
