Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - starting problems
Old 12-15-2010, 02:40 PM   #2
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 02 ZX 3 TURBO , MURDERED.
Points 5,573, Level 48
Points: 5,573, Level: 48 Points: 5,573, Level: 48 Points: 5,573, Level: 48
Level Up 12% Completed
Level up: 12% Level up: 12% Level up: 12%
Forum Activity 4%
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
OK if I am understanding you correctly. The engine is cranking over but wont start. Then after you hit the gas pedal it will start right up, and every time after that. Try this. The first time you go to start , turn the key to on, not crank position, and listen for the fuel pump, ( a humming or whining sound) should last a couple of seconds. It pumps up fuel pressure. Sound like you are losing your prime. silly question but is the fuel filter pointing in the correct direction. It will have an arrow on it...
iroc34 is offline
