Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Need Some Help with an SVT Please!
Old 12-14-2010, 08:53 PM   #17
golfitup
golfitup's Avatar
Fan#: 81087
What I Drive: #93 H-Street 2002 Focus SVT
Points 1,017, Level 17
Points: 1,017, Level: 17 Points: 1,017, Level: 17 Points: 1,017, Level: 17
Level Up 17% Completed
Level up: 17% Level up: 17% Level up: 17%
FF Reputation: 1 golfitup Good Standing Member
Originally Posted by GodLovesUgly View Post
you're going to swap out the stocker for the 18mm?
Well, there is a lot of thought in this idea.
Typically, as old racers will tell you: FWD cars must grip in the front and rotate in the rear. Since the front wheels have to do both turning and acceleraing/braking at the same time, the maximum grip will be necessary.
BUT, since its a mcstrut car, there may be a trade off point. Some people say no, others say yes. For example, a very well known fwd autox source is here citing the smaller front bar: http://farnorthracing.com/autocross_secrets10.html. Here is talks about the proper FWD car autox setup and the KEY tradoff.
It will definitly be course dependent. The local series will be tighter with less speed and more sharp turns than the National Tour events, so there may need to be a change between the two.
IDEALLY would be a front bar adjustable between 19-21. Does this exist?
golfitup is offline
