Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus is not a 1/4 mile car ...
Old 12-13-2010, 11:57 PM   #78
Fan#: 50487
What I Drive: 02 mustang GT, 08 mini cooper S
FF Reputation: 1 underoath Good Standing Member
Originally Posted by NateV8 View Post
Again. Not the best for drag racing.
With full suspension, advanced timing, gear and exhaust a fox runs mid to high 12s all day. With a cam you should run mid 12s easy.
And the 4.6 2v sucks on motor. Unless you are running the trick flow heads, boost is the only way to go on them.
WRONG, you can do those same mods as you posted on the fox to the 2v and run the same times... theres a bunch of stock longblock 2v's with a set of cams, gear, tires, little suspension and bolts going low 12's.
underoath is offline
