Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replacing air box with K&N air filter. HELP
Old 12-08-2010, 10:03 AM   #14
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,258, Level 100
Points: 31,258, Level: 100 Points: 31,258, Level: 100 Points: 31,258, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
Posted via FF MobileCan`t see what kind of car, what SRI, or which hose you are plugging in where from here. General info - never plug a crankcase ventilation tube! Worst case, if it`s sealed REAL good is that engine seals blow out & you neeed a rebuild just to replace them...... Installed in the same order as stock, with hoses in the same relationship to filter, MAF, and throttle body as they were originally is best - other options defeat part of the emissions system, and except for some extreme race & turbo applications do NOT increase performance... Pulling the battery negative for a bit to reset the computer so it can learn the new setup quicker is recommended for any change that effects the breathing of the engine, even if a relatively minor change... Hope this helps, get back with more info/questions & the members here will try to help out....
sailor is offline
