Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Headlight/Fog light Restore! (56k stay away)
Old 12-07-2010, 02:17 AM   #1
WiscoGTI
Turböner
WiscoGTI's Avatar
Fan#: 70225
What I Drive: 2002 VW GTI
Points 182,482, Level 100
Points: 182,482, Level: 100 Points: 182,482, Level: 100 Points: 182,482, Level: 100
FF Reputation: 33 WiscoGTI Great Standing Member
Buy-Sell-Trade Rating: (9)
Tools used:
-Cordless drill w/ extra batteries (I went through 3 of them)
-3M Headlight restore kit (Use the instructions!!!)
-Plastx rubbing compound
-Shop rags
-Lots-o-tape
-Spray bottle filled with water
-A good shop stool!
Here she goes..
Before:
After 400-grit:
After 800-grit (forgot to take pictures) and 3000-grit wet sand:
After the rubbing compound:
Success! After one more pass with the 2000-grit wet sand and rubbing compound:
The final product (after a good washing):
The 3M kit really does work! It also ended up being a few bucks cheaper at my local Autozone than buying all the sandpaper and rubbing compound seperately. And it's soooo much easier than doing it by hand. All you need is a cordless drill (as seen in some of the pics.) Although their instructions say to only do one row of tape, just double it up (one strip on top of the other.) But I HIGHLY recommend doing about 3 or 4 rows of tape wide jusssst in case. In order to hit some of the corners, you have to get in very close. And my paint around the headlights ended up catching some 800-grit in a couple places, all because there just wasn't enough tape. And another thing, make sure you're not sanding areas of the headlight that you don't have 100% visual of. It sounds like common sense, but after a while you just don't think about it. In order to hit the bottom lip of the headlight, you really need to get down there and look underneath the sander because I went over the tape without even noticing I was that close. So, just put in the extra 5 minutes for more tape.
Also, I was told this could be done in about 40 minutes..now, either I'm just slow, too anal retentive, or else that is just complete bullocks. I spent well over 2 1/2 hours on this tonight. And I really didn't even get the fog lights as well as I could have. So definitely give yourself some time to complete this.
WiscoGTI is offline
