Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2005 Dual Halo Projector Retrofit Project
Old 12-03-2010, 02:33 AM   #152
FecalRocket
FecalRocket's Avatar
Fan#: 75116
What I Drive: 07 Liquid Gray ST
Points 1,697, Level 23
Points: 1,697, Level: 23 Points: 1,697, Level: 23 Points: 1,697, Level: 23
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 5%
FF Reputation: 3 FecalRocket Good Standing Member
The glass bubble is a projector. For these headlights, they are designed for halogen bulbs. The OP retrofitted them with HID projectors which you see on most luxury cars.
Those are the low beams, the inside are the high beams. I have mine set to have low and high beams on at the same time but you have to open the steering wheel column and add a wire there to do it. This is safe to do in these headlights without a meltdown. Halos get spliced into the parking/running lights using a quick splice that can be found at radioshack or elsewhere. Turn signals still work the same. The turn signal harness has 3 wires. One for ground, one for turn signal, and the other for running/parking.
FecalRocket is offline
