Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - From stock 2001 S2 to new 450hp+
Old 11-27-2010, 12:32 PM   #115
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Originally Posted by 1turbofocus View Post
If you havent used it already you can use the oil plug behind the coil for oil psi , If you have you have a plug right behind the starter you can remove and use that
If you use the oil sending location and "T" it make sure you use steel fittings or the "T" could brake and has on many peoples cars
The water temp can be done a few ways , making a short tube with the bung for the temp sensor in the top hose , HTP i think makes a costly thurmostat housing that you can use
Tom
It is the SVT aux cluster, oil temp and pressure. The port behind the coil pack is the turbo oil feed. Just heard this cluster is not accurate, but is a space solution, do not know if possible to install.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by
Mother Focus is offline
