Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How To: Change SVT Gauge Color
Old 11-15-2010, 02:10 PM   #2
mtothaj
Fan#: 77917
What I Drive: 2003 SVT ZX5
Points 2,006, Level 27
Points: 2,006, Level: 27 Points: 2,006, Level: 27 Points: 2,006, Level: 27
Level Up 4% Completed
Level up: 4% Level up: 4% Level up: 4%
FF Reputation: 6 mtothaj Good Standing Member
Buy-Sell-Trade Rating: (3)
How to on how i changed the color of my odometer. This will go between steps 15 and 16 on the previous how to.
1. Remove the black plastic clip surrounding the odometer. Be extremely careful because the odometer is very fragile and can crack easily!!
2. The actual odometer is made up of three layers. There are two layers of glass and under that there is a piece of paper that has a green tint on the back. By sliding a razor blade between the bottom glass and the white paper remove the paper from the odometer.
3. This is what it will look like.
4. Using the paper you removed trace that shape to a white piece of printer paper and the same transparency sheet you used earlier.
5. Now install those sheets back into the odometer with the white paper on top of the colored transparency sheet.
6. Install the black plastic clip.
Done
mtothaj is offline
