Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - tczx3's complete how-to on front wheel bearing replacement
Old 11-02-2010, 06:41 PM   #17
ChrissyL
Trying to Focus
ChrissyL's Avatar
Fan#: 64813
What I Drive: '13 Performance Blue ST3
Points 1,407, Level 21
Points: 1,407, Level: 21 Points: 1,407, Level: 21 Points: 1,407, Level: 21
Level Up 7% Completed
FF Reputation: 13 ChrissyL Great Standing Member
This was a first-rate write-up. Well done and thank you to tczx3!
Originally Posted by TheGeak View Post
Wow...how did you EVER get your Strut Pinch Bolt loose? Looks like you managed it with a 3/8" ratchet with a 15mm socket...I'm on my way out to Sears to buy a 15mm 1/2 drive socket and a 18" breaker bar! I've tried WD-40, PB Blaster, Heat, hammer, and just wow...it won't budge. I figure we will see how it holds up against the laws of Physics!!...Breaker Bar and Socket worked, bolt is loose!...
A mechanic's trick that sometimes helps loosen badly rusted bolts/nuts when other methods don't seem to be getting anywhere: try tightening the bolt/nut by about 1/8th turn first, then reversing your ratchet to loosen. Repeat a few times. This approach will help break down the corrosive "welding" in the threads. May sound counterintuitive, but it often works.
All my relations, Christine
NW Posse #17
"Straight roads are for fast cars. Curvy roads are for fast drivers."
ChrissyL is offline
