Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 100,000+ Mileage Foci, Post here..
Old 10-24-2010, 11:25 PM   #475
jesusamares
jesusamares's Avatar
Fan#: 64713
What I Drive: 2000 Rainforest SE SOHC SPI
FF Reputation: 1 jesusamares Good Standing Member
I have a 2000 ford focus spi sohc
I bought it for $300 and well it would turn off whenever i was on a stop light,
To fix the problem of it from turning off i made it idle high,
Then one day I looked for leaks and found that the EGR Valve gasket was broken and it wad missing a screw, so basically it wasnt on there tight enough. In the process of trying to find the problem I had changed the fuel injectors, fuel pump, fuel filter, valve cover gasket, ignition coil, spark plugs abd wires, motor mounts and tranny mounts, tranny oil, engine oil. And i believe thats all. Now i have the shocks syuts tie rods inner and outer and sway bar end links all moog and kyb. Also imma change out the rear bushings and the bearings. I have 147700 miles and i believr i bought it at 125000. I hope I can make it run better and smoother than stock.
!Stock_2000_Focus!---[S.E.-S.O.H.C.-S.P.I.]
jesusamares is offline
