Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - AEM wideband to xcal3 question
Old 10-20-2010, 09:05 PM   #59
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,440, Level 29
Points: 2,440, Level: 29 Points: 2,440, Level: 29 Points: 2,440, Level: 29
Level Up 94% Completed
Forum Activity 11%
Activity: 11% Activity: 11% Activity: 11%
Buy-Sell-Trade Rating: (3)
Originally Posted by FocusRacingAustrali View Post
starts off at 14.5 goes up and go down and goes all the way up to 17.9 then goes - - -
- - - = End of gauge maximum displayable range.
The problem I have is what 12v power and ground do you go off????
Ground on the bare metal exposed fuse box housing in the passenger compartment. In other words, crimp/solder a ring or split ring electrical connector on the black wire end and ground it directly to the chassis by drilling a pilot hole and using a self tapping screw.
The fuse box housing is convenient; any exposed metal surface on the car chassis will do.
Connect the red wire to a switched power source. A switched power source is one which is dead with the ignition off. ex. wipers. Pick any electrical accessory that doesn't work when the car is turned off. If you use the fuse panel as a power source, you have your pick. (If you want to set it up crudely for testing purposes, you can cram the exposed red wire end into a fuse socket together with the "regular" fuse. Mind any exposed bare wires and put an inline fuse in the red wire to protect against shorts.)
BC_ZX3 is offline
