Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Protech Autosport Duratec Oil Filter Adapter
Old 10-11-2010, 04:06 PM   #31
Fredness
Fan#: 26710
What I Drive: 2005 Cloud White ZX3
FF Reputation: 7 Fredness Good Standing Member
Originally Posted by PSUrivie View Post
How much total oil do you use when you add the bigger filter?
I just used a larger filter (no adapter - possible ground clearance issue on lowered vehicles, mine is not lower than the oil pan - I'm not worried) and it took 5qts top get to the bottom of the "crosshatch" - so a hair more than 5qts to be dead-on when warm.
Wix 51516 is stock - I'm guessing they are using the 51515.
If so, it is the same thread, same bypass rating, same Anti-Drain Back Valve, with a few differences:
.4" Taller
.7" Wider
higher burst rating (290lb vs. 275)
and better filtration media = cleaner oil
For the techies:
Wix 51516: Beta Rating 2/20=14/31 OR 50% efficient at removing 14 micron particles and 95% efficient at 31 microns
Wix 51515: Beta Rating 2/20=13/23 OR 50% efficient at removing 13 micron particles and 95% efficient at 23 microns
That's about an 11% increase in oil capacity (cooler and lasts longer).
'05 ZX3 ("S") Team Duratec #56
Engine: Modified MBRP Stainless Exhaust, K&N AirCharger, SCT LiveWire (dealer), ScanGauge, poly "dogbone" bushings.
Stereo: '05 Mustang Shaker500 H/U, Polk DB570's and an Infinity BassLink SubWoofer.
Fredness is offline
