Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - “How To”-Getrag Shift Linkage-Counterweight Removal
Old 10-05-2010, 06:32 AM   #347
samus
Fan#: 53177
What I Drive: 2002 Pitch Black SVT
Points 136, Level 2
Points: 136, Level: 2 Points: 136, Level: 2 Points: 136, Level: 2
Level Up 72% Completed
FF Reputation: 2 samus Good Standing Member
The best thing you can do to the counterweight is remove it, drill out the weight from the mount with a 3/8" bit, and stack 15g fender washers on. The stock weight is around 200g, I found the ideal weight with a short throw shifter was 130g, or 7 washers + M10x1.25x30mm bolt. Get all zinc platted stuff from Homo Depot and it'll look good, too.
The benefit of using washers is you can customize the weight until you find the right oomph to pull through the gears. We all have different expectations.
samus is offline
