Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Instrument Cluster Home-repair
Old 09-26-2010, 05:53 PM   #7
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
I am afraid I'm going to have to take issue with your comments whynotthinkwhynot. Having worked in the electronics industry for the past 30+ years, mostly in circuit board design- there is not a commercial process that I am aware of, called 'cold soldering'. Most commercial components are soldered by 'wave soldering', where the placed board is passed through a vat of molten solder, making the joints. Surface mount components can also be done this way, but they are generally 'reflowed', where solder paste is applied to the board- the component placed- then infra red heat is used to melt the solder. The vast majority of problems with circuitry these days comes from the use of lead-free solders where the high levels of tin in the solder have led to poor solder joints and the formation of 'tin whiskers' which cause short circuits.
If you think I've been able to help, just say
niggly51 is offline
