Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Instrument Cluster Home-repair
Old 09-26-2010, 02:40 AM   #4
niggly51
niggly51's Avatar
Fan#: 74542
What I Drive: Xantia 1.9td & Wifes Focus 1.4
FF Reputation: 19 niggly51 Great Standing Member
Welcome.
I would be very surprised if your cluster repair proves to be a long term fix for the speedo zeroing problem. The Focus suffers from two faults in this area. One, as you have found, is poor solder joints on the instrument cluster, and the second is an internal fault in the VSS (Vehicle speed sensor). This item is in the top of the transmission housing and supplies the ECU with data relating to vehicle speed and displays this on the speedo and also has an input to fuelling. Once replaced with a new updated item, it is unlikely you will suffer this problem again. A difficult item to change, and costs around 40, but certainly worth doing.
If you think I've been able to help, just say
niggly51 is offline
