Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Harmonic Balancer Bolt Stuck
Old 08-25-2010, 12:38 AM   #11
jjzx2sr
Fan#: 74691
What I Drive: 2001 Green Focus ZX4
FF Reputation: 3 jjzx2sr Good Standing Member
I was going to recommend using the old crank the over the engine with a breaker bar attached also.If you dont mind buying a pump or front crank oil seal. heat the bolt up just a touch with an acetylene torch to loosen it up. If not make sure the engine can not turn over and use a 3/4 inch or 19mm drive breaker bar and a really long pipe.
But seriously a little heat can't do anything but help the situation. Notice i said a little.
jjzx2sr is offline
