Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - CFM Tubular Front Control Arms NOW AVAILABLE!
Old 08-17-2010, 01:47 PM   #30
kbrownfocus
kbrownfocus's Avatar
Fan#: 14709
What I Drive: 2009 Dodge Journey waiting on my ST
Points 289, Level 5
Points: 289, Level: 5 Points: 289, Level: 5 Points: 289, Level: 5
Level Up 78% Completed
FF Reputation: 1 kbrownfocus Good Standing Member
Originally Posted by illinipo View Post
the knowledge base required for properly doing aero engineering is COMPLETELY different from the knowledge base required for properly designing mechanical parts. As a mechanician with friends in aero engieering, I can assure you that my friends are not qualified to design these arms. (and I also recognize that I cannot design airplanes...)
Im sorry to be blaint, but the materials and the design of these LCA's are designed the same way landing gear for jets and airlines are, they are made as one peice, not tigged together and seamed. Sad thing is its 500% over the stock LCA's witch are weak and just straight junk. and an aero engineer should make these because the simple fact that if it is made the same way landing gear is made then hell a 4000LBS max vehicle realy isnt anything to even put the least amount of stress on the tubing.
kbrownfocus..02 Yellow ZX3
ZETEC Crew #341
kbrownfocus is offline
