Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Miles on Zetec
Thread: Miles on Zetec
Old 08-07-2010, 06:00 PM   #533
Fan#: 35601
What I Drive: 2003 FORD FOCUS ZTS 4Cyl 2.0L Specs
FF Reputation: 1 MegaToy Good Standing Member
Miles on Zetec ZTS, automatic
2003 Red 2.0l DOHC ZTS
Bt. new, 6 miles - now, 147k - STILL screamin'
Toys added:
Steeda CAI, Screamin' Demon Coil, Live Wires, Autolite Copper core plugs,
ManaFlow High Flow CAT & CAT BAK System, JBA Headers, VF Lower Motor Mount.
Drilled and Slotted Front rotors w/ Ceramic Pads.
Replaced - Maintance Items:
replaced the power steering pump
changed transmisson fluid about 50,000 mi.
fuel pump (my fault, ran out of gas)
Sway Bar stabilizer links, up front
rear upper control arms to correct intense amount of negative rear camber.
replaced shocks and struts (turns out, excessive tire wear was dut to Firestone's inabilty to balance the tires!)
Try Road Force Balancing
timing belt, idler and adjustable pulley, water pump, thermostat & thermostat housing,
valve cover gasket, fuel filter, rear brake hub and bearings,
PCV Valve
rear brake shoes, front wheel bearings & spindle nuts, Cold Idle valve, DPFE valve, removed EGR and associated items :)s, Transmision / motor mount.
Interior Items:
Panasonic Head Unit w/ JBL Amp, JBL sub woofer and Amp.
All new PUNCH speakers
Window Tint
MegaToy is offline
