Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - tried everything electrical problem on 05 ford focus need help
Old 08-07-2010, 07:15 AM   #22
sparky34kv
Fan#: 63383
What I Drive: 2004 Blue ZTW Wagon, 2.3 L Duratec
Points 618, Level 12
Points: 618, Level: 12 Points: 618, Level: 12 Points: 618, Level: 12
Level Up 36% Completed
FF Reputation: 1 sparky34kv Good Standing Member
Originally Posted by Grumpy View Post
As the car has been doing this for a period of time but starts OK which suggests the battery has been getting charged sufficiently, so I doubt that it's the alternator. In the main fuse/relay junction box there is a relay called the power hold relay that puts battery power through a hot at all times 20 amp. fuse to the PCM when the Ign. switch is at On or Start. After checking the battery connections as suggested, I'd swap out this relay. It should be common knowledge by now, but I"ll repeat it.......NEVER, EVER disconnect the battery when the Ign. switch is selected ON, including any attempt to see if the alternator is producing current. It's a good way to zap the PCM and/or the alternator. The FSM for any modern car will have this warning.
Thanks for the info, now I know. I don't see why it would affect anything since it is electrically the same with or without the battery, but if the factory service manual warns against it I won't suggest it to anyone again.
sparky34kv is offline
