Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - tried everything electrical problem on 05 ford focus need help
Old 08-06-2010, 10:06 AM   #17
sparky34kv
Fan#: 63383
What I Drive: 2004 Blue ZTW Wagon, 2.3 L Duratec
Points 615, Level 12
Points: 615, Level: 12 Points: 615, Level: 12 Points: 615, Level: 12
Level Up 30% Completed
FF Reputation: 1 sparky34kv Good Standing Member
If you know someone that can work on the car, unless you do yourself, not trying to be patronizing. Once the car is started, disconnect one of the battery cables. Once the battery is disconnect the car is running completely off of the alternator, which is it's purpose. If the car dies, as it probably will, the alternator is the fault. As somone else stated, if it isn't able to put out enough power, the car will draw from the battery and as you drive faster the car draws more power, so something has to give. If your battery went bad, or went dead, charging it could have killed the alternator. Modern alternators are only designed to run the car and slightly charge a battery, they cannot put out the power needed to recharge a depleted battery, it burns out the regulator. Good luck, I'd offer to help but the commute would kill me.
sparky34kv is offline
