Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - WEIRD Battery light on, but no problems...?
Old 07-26-2010, 06:06 PM   #17
arlenn
Fan#: 67609
What I Drive: 2005 Black ZX5 SES
Points 3,927, Level 39
Points: 3,927, Level: 39 Points: 3,927, Level: 39 Points: 3,927, Level: 39
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 3%
FF Reputation: 17 arlenn Great Standing Member
Originally Posted by Soccercop View Post
Now, onto the reverse light switch.
I'd replace the alternator. If you're not confident doing it yourself-I wouldn't hesitate to take it to Pep Boys (as silly as that sounds). From what I've read-they gave me a solid price.
I have a contributed to a thread on this, its quite simple and likely the switch.
I had identical symptoms to your alternator, when a load was applied it would drop just below 13v. I changed the alternator myself, it took 2h out and about 30min back in. doing it again, i could probably have it out in about 30. it is a bit of work but only nut and bolt work. Its a good excuse to change the belt and i replaced the tension idler at the same time as the bearing was trashed.
arlenn is offline
