Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ask your spark plug, wires and coil questions here
Old 07-08-2010, 01:34 AM   #386
Tyler T
Tyler T's Avatar
Fan#: 42066
What I Drive: two '02 SVT's
Points 1,197, Level 18
Points: 1,197, Level: 18 Points: 1,197, Level: 18 Points: 1,197, Level: 18
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 5%
FF Reputation: 2 Tyler T Good Standing Member
the 411 on spark plugs: http://www.motorsport-developments.c...AF272_tech.pdf Iridium is preferable because the thinner center electrode diameter allows for a higher quality spark and because iridium degrades much slower than copper it allows you to run a larger gap (or just replace your coppers constantly). Also the AZFS22C is the proper heat range for a regular Zetec but I don't think it is the proper heat range for a SVT. http://sparkplugs.com/results_app.as...1&AAIA=1385580 also helps out a lot for the specs for different plugs and they have some of the best customer support I have ever worked with.
Tyler T is offline
