Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ask your spark plug, wires and coil questions here
Old 06-29-2010, 04:15 PM   #381
superunkn0wn
superunkn0wn's Avatar
Fan#: 75120
What I Drive: 2011 Mazdaspeed3
FF Reputation: 1 superunkn0wn Good Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by pstrjeff View Post
I have oil sitting in the tube where my spark plug wires go. How do i fix that?
You need to replace your valve cover gasket. Oil from around your camshafts is seeping down into the spark plug area through a tear or separation in the gasket.
From what I've read, a bad VCT solenoid can also leak oil. That's the module to the left of your spark plug wires when you remove the black plastic "Powered by SVT" cover from the valve cover. I believe you would be able to see a trail of oil leading back to the VCT module if this is the case.
superunkn0wn is offline
