Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - The Importance of Toe-in or Toe-out
Old 06-11-2010, 07:15 AM   #52
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,635, Level 100
Points: 31,635, Level: 100 Points: 31,635, Level: 100 Points: 31,635, Level: 100
Forum Activity 100%
Posted via FF MobileWell, things can wear out at any mileage if damaged, you`re at a mileage like my own where wear items may start to need replacement, or may go a lot longer depending on luck and useage... Geezer`s specs in the sticky are tighter than stock Ford specified ranges, give good results. Ford has tightened range on newer models, old specs were too wide in practice for many and caused issues like you have even when "in spec". Best wear, handling, economy with sticky specs , ask shop to use them instead of std #s, or keep looking for one who will - it`s worth it!
sailor is online now
