Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 06-11-2010, 07:00 AM   #76
FordZX32000
Fan#: 33469
What I Drive: 2000 black ZX3
Points 982, Level 16
Points: 982, Level: 16 Points: 982, Level: 16 Points: 982, Level: 16
Level Up 82% Completed
FF Reputation: 1 FordZX32000 Good Standing Member
Originally Posted by sailor View Post
Posted via FF Mobile Needs to come off for timing check & set. Making your own marks to "cheat" by replacing belt without checking & resetting timing as needed could be done, but Ford wanted near perfect timing, not just close - so they made it possible through their adjustable sprockets. One small oops and you`re off quite a bit, is it wort chancing that? Plus you would probably have a harder time getting it close by the "cheat" of not checking the cams than by doing it right. Your call, if not VERY experienced and knowledgeable don`t even THINK of trying your own method....really not worth it...
Just checking I was told that valve covers didn't have to come off and I needed that confirmation.
Would the timming need to be set and or checked if just replacing the belt that hasn't broke or lost teeth yet ?
Thanks Sir....
FordZX32000 is offline
