Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 06-11-2010, 05:48 AM   #75
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,903, Level 100
Points: 31,903, Level: 100 Points: 31,903, Level: 100 Points: 31,903, Level: 100
Forum Activity 100%
Posted via FF Mobile Needs to come off for timing check & set. Making your own marks to "cheat" by replacing belt without checking & resetting timing as needed could be done, but Ford wanted near perfect timing, not just close - so they made it possible through their adjustable sprockets. One small oops and you`re off quite a bit, is it wort chancing that? Plus you would probably have a harder time getting it close by the "cheat" of not checking the cams than by doing it right. Your call, if not VERY experienced and knowledgeable don`t even THINK of trying your own method....really not worth it...
sailor is offline
